Unable to connect/download to S32K388EVB using iSystems and winIDEA
MCH1986GN
After configuring winIDEA for S32K388EVB, using iSystems Debugger I am unable to download code, keep getting an error message.  Please see attachment for EVE log file and please advice.
Charles
Julián_AragónM
Hi @MCH1986GN,
I apologize for the inconvenience, but the support for winIDEA or iSystems is out of our scope for the online community. I would recommend contacting iSystems instead for support.
You can also look at their Setup and Configure Hardware guides from their page.
Julián
MCH1986GN
Ok, but my understanding is that there is a jumper that needs to be removed from the S32K388EVB for the elf file to be programmed.  Do you know what jumper needs to be removed?
I have the Q289 package, if that helps.
Julián_AragónM
Hi @MCH1986GN,
The S32K388 is NPI product which is not publicly available. Please get in touch with one who provided it to you and as for information you are interested in. Such product must be provided directly by NXP representative, who has right and access to documentation, SW, etc...
Julián
