Hello:
is there has any way to disable watchdog? i enabled the watchdog and feed it in the program, but in the some situation(such as receive some commands from CAN), i want to disable it, is there has any way to do it except set FNMC or SDMC, because it seems MPTNV only can be programed 200 times. but i maybe do disable/enable watchdog thousand times.
