UDS on CAN for S32K14x FIFO size configuration
pratikkul26
I'm using unified bootloader v2.1 on s32k14x.
I'm able to run all the services, I'm using transfer data service(36) with block size of 0x80(128byte)
Now I want to increase the block size for data transfer of minimum 256byte or more.
I tried to change the RX_BUS_FIFO_LEN , RX_TP_QUEUE_LEN & TOTAL_FIFO_BYTES but in can_tp_init function I'm getting error while creating fifo. "ApplyFifo" function.
