[Support] How to rom writing FS32K148 by Behive204 machine?
BradNguyen
I am using Behive 204 programer machine to Rom writing FS32K148 and try to find correct way to do it.
While do setting step, there are some option need to choose (FlexNVM partition/FLASH/DFLASH/EEPROM) but i dont know which option is correct to choose.
(please refer the picture)
Please help me about this case.
VaneB
Hi @BradNguyen
The S32K148 It is programmed by FLASH and according to the information you provide, you are doing it right, I suggest you contact Elnec support through the following link: Technical support | Elnec
B.R.
VaneB
BradNguyen
Dear bros,
I try to tick on Flash in the 1st time  and Flash/DFlash in the 2nd time but software is not wrote into the FS32K IC after mount into PCBA. I think there was something wrong at setting at behive 204 machine but i could not find out correct way. please help with thanks
BradNguyen
I attach the picture of setting
