Stacking in "Default ISR", s32k116
fcatkaya
I am using CAN, FTM, and also PWM on a S32K116 MCU. I use can_pal, pwm_pal and flexTimer libraries. When I start the program it stacks on Default_ISR, when I disable CAN or PWM the problem disappears.
I would appreciate if you help me
Senlent
Hi@fcatkaya
     Please check your clock configuration, this may be caused by a clock problem.
     If it is convenient, you can send your code and I will help you debug it.
BR!
     Jim,
