Inputs considered are on SE0, SE1 and SE5 on ADC0. Back to back triggering has been enabled. If SE5 is disabled, correct values are obtained on the SE0 and SE1 channels. When SE5 input is enabled, all the values (var1, var & var3) show up as 0.
Any help?
PDB0->MOD = 1200;
PDB0->IDLY =1200;
PDB0->CH[0].C1 = (PDB_C1_BB(0x02)
| PDB_C1_TOS(0x01)
| PDB_C1_EN(0x03));
ADC_DRV_ConfigChan(INST_ADCONV1, ADC_INPUTCHAN_EXT0, &adConv1_ChnConfig0);
ADC_DRV_ConfigChan(INST_ADCONV1, ADC_INPUTCHAN_EXT1, &adConv1_ChnConfig1);
ADC_DRV_ConfigChan(INST_ADCONV1, ADC_INPUTCHAN_EXT5, &adConv1_ChnConfig2);
ADC0->SC1[0] = ADC_SC1_ADCH(0); // SC1A[ADCH]
ADC0->SC1[1] = ADC_SC1_ADCH(1); // SC1B[ADCH]
ADC0->SC1[2] = ADC_SC1_ADCH(5); // SC1F[ADCH]
var1 = ADC0->R[0];
var2 = ADC0->R[1];
var3 = ADC0->R[5];
the setting does not look right for 3 channels conversion in back-to-back mode. You should have
PDB0->CH[0].C1 = (PDB_C1_BB(0x06) | PDB_C1_TOS(0x01) | PDB_C1_EN(0x07));
Channel delay 0 register should be configured too, or simply clear TOS if delay of first sample is not needed.
Also you should read result from R0, R1, R2 registers
var3 = ADC0->R[2];
BR, Petr
