Single write digital outputs with read-back
674件の閲覧回数
smt87
I want to use GPOERB_SWTEST_CMP feature in safety manual to check if the read data equals the written data. Which register of s32k146 should I activate for this feature?
632件の閲覧回数
JRoberto
@smt87
Well, I can't tell you the best way to implemented because it depends on your specific needs, but it could be as straight forward as reading back the pin after it has been written and compare this pin with the intended value you wanted to write in the first place.
Best Regards!
3 返答(返信)
643件の閲覧回数
JRoberto
@smt87
The GPOERB_SWTEST_CMP is a safety function that should be implemented by software. There is no register called GPOERB_SWTEST_CMP to do it automatically
Best Regards.
641件の閲覧回数
smt87
How can I implement this feature? Is there any sample code for this?
633件の閲覧回数
JRoberto
@smt87
Best Regards!
