Segger debug configuration not showing in S32 design studio 2018.R1
15,367 次查看
rohit_rawat
Hey All,
I'm not getting any GDB segger jlink configuration in debug configuration in my S32 design studio as like GDB hardware debugging, GDB PEMicro interface debugging etc. but can not get the same for GDB segger jlink.
Thank you.
15,303 次查看
jiri_kral
This is strange, as far as I know - S32DS for Arm is not supporting S32 Debug probe. Please try to create new workspace and try it again:
9 回复数
15,352 次查看
danielmartynek
When you create a new project, you need to select Segger J-link GBD server as the debugger.
BR, Daniel
15,346 次查看
rohit_rawat
Dear sir,
I did not get any option related to Segger jlink in debbuger while creating new project
I am getting only PE and s32 debugger here.
Please resolve the issue.
Thank you.
15,341 次查看
danielmartynek
You can check for updates / new SW.
But I would recommend using a newer version of the Design Studio.
S32 Design Studio for ARM 2.2 – Windows/Linux
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
S32 Design Studio 3.3 – Windows/Linux
BR, Daniel
15,328 次查看
rohit_rawat
Dear sir,
I downloaded S32 Design Studio for ARM 2.2 and installed it online. After installing i got segger jlink debugger but this S32ds showing errors "make" not found in PATH, Ld error etc. as shown in fig.
15,301 次查看
jiri_kral
Did you created your project as a S32DS application project?
With this option all paths should be configured correctly for new project. You can check it in project properties:
Jiri
15,317 次查看
jiri_kral
on your screenshot is probably S32DS v3.3 - not S32DS for ARM v2.2. Please make sure that you installed correct S32DS Version.
Jiri
15,310 次查看
rohit_rawat
Dear  sir,
It is S32 Design Studio for ARM Version: 2.2. Please review the attached image.
Thank you
15,304 次查看
jiri_kral
15,296 次查看
rohit_rawat
Dear sir,
After switching working it works smoothly. Thank you for your initiative.
Thank you sir
