SIM display "??"
SIM display "??"
814420552
 why the following EEERAMSIZE  & DEPART  display "??"  when debug the example code ?
814420552
Dear Alexis,
      MCU:S32K146, thank you!
Alexis_A
Hello Kui,
If you want to check these two registers you would need an example that configures these two sections, for example in the SDK, there's an example called flash_partitioning that configures these two registers:
Also, I don't recognize this interface that you're using, are you using the latest S32 Design Studio?
Alexis Andalon
814420552
    hello Alexis,
               MCU is S32K146,
                but when debug, register FCFG1 can't display. I don't know why it is so!
Alexis_A
Hello Kui Wu,
Only to check, could you try updating to the latest S32DS version? I see that you're using the 2018 and there's a new one available in the following link.
Alexis Andalon
Alexis_A
Hello Kui,
Can you let me know which device are you using?
Alexis Andalon
