S32k324 data flash size with HSE activation/deactivation (block 4)
563件の閲覧回数
tigercat
s32k3xx RM says that (s32k3xx_memory_map_xlsx)
1) s32k324 has 128K data flash (1000_0000 ~ 1001_FFFF) with HSE deactivation
2) s32k324 has 88k data flash, 39K data flash reserved with HSE activation.
However, HSE-B Firmware Reference Manual says that s32k324 has 256k data flash like below
1) 1000_0000 ~ 1002_FFFF ( 128K for application )
2) 1003_0000 ~ 1003_FFFF (128K for reserve )
1. What is the exact size of data flash of s32k324?
Thank you and regards,
Jongtae
559件の閲覧回数
tigercat
Plus, If I changed memory map into AB swap, then is there any chance to roll back to FULL_MEM?
