I had tested the S32K344'wakeup function,and the external I/O can wake up from standby,but the Rtc-API can't .I think there may be a problem with the configuration,so i want the S32k344's RTC wakeup project,could you help me?
thanks.
已解决! 转到解答。
Hello
Thanks your reply.I have found the problem that it is some register not be enable.
在原帖中查看解决方案
Hello @luyq,
There is no RTC-API Wakeup example yet.
Can you please share your project so that we can test it?
If you don't want to share it here, you can create a ticket.
Please send your email, I will send the email to you conveniently.
Besides, I found that sometimes I can wake up, sometimes not.I will send you the project,please check it for me.Thanks very much.
