S32k144 watchdog
S32k144 watchdog
zhouqichen
  hell0 ,S32k144 When the watchdog is turned on, the can cannot communicate, but it is found during the test that the dog can be fed successfully for 4s, which is much longer than the can communication time. And the serial communication is normal
lukaszadrapa
this seems to be pure application issue. Not sure how to help, this would require some extensive debugging.
Lukas
