S32k144 occasionally fails to wake up from VLPS mode
kawadaxi
S32k144 occasionally fails to wake up from VLPS mode and freezes unless powered on again. I now use external GPIO interrupts to wake up. This problem is prone to occur when frequently entering VLPS and waking up again.
Thanks.
kawadaxi
Thanks for your reply, I'll try it.
danielmartynek
Hi @kawadaxi,
It could because of this erratum: ERR011063: SMC: An asynchronous wakeup event during VLPS mode entry may result in
possible system hang scenario.
https://www.nxp.com/webapp/Download?colCode=S32K144_0N57U
Make sure you have the workaround implemented.
