S32k144 maintains normal operation of RTC in case of powerdown
kane123Hu
I use S32K144 and now I have a requirement: when VDD loses power, the RTC clock should keep running normally and the power consumption should be less than 10ua. I have checked that there is no separate RTC power supply pin on the chip hardware. Can we only adopt the solution of using an external RTC clock chip?
davidtosenovjan
Yes, it will be needed to use external RTC device.
davidtosenovjan
