Two pins always keep low level.Routine called S32K144_Project_LPI2C.I'm not connecting anything in two pins.
Solved! Go to Solution.
Would you please test it after external pull up resistor connected?
Internal pull up resistor may not work for I2C pins.
Robin
Hi 郑文豪,
Please refer "52.3.2.6 Pin Configuration" of S32K1xx MCU Family - Reference Manual .
External pull-up resistor are needed.
Robin
Code:
Robin
