S32k144 CSEC error state
846 次查看
fan1234
Hi, team:
     from AN5401 , i know the error is reported in the “Error Bits” field when any error occurring during the CSEC command execution, and i want to confirm what's the impact with the chip?
     for example, if i update a key without increase the counter value, the error bit will be "CSEC_KEY_UPDATE_ERROR", then the key will be unavailable or what, and will it affect the use of flash modules?
Thanks in Advance
Cor
标记 (1)
806 次查看
lukaszadrapa
Hi @fan1234
if you get "CSEC_KEY_UPDATE_ERROR", nothing will happen. The  original key can be still used, it's just not updated because you provided wrong data. It does not affect flash modules.
Lukas
807 次查看
lukaszadrapa
Hi @fan1234
Lukas
791 次查看
fan1234
other error bits will be the same? will any error of csec affect flash modules or original kes?
