S32k116 ADC Polling not working
1,181件の閲覧回数
MohameddRIAD
I've been working on S32k116 EVB and using SW32K1_RTD_4.4_1.0.1 AUTOSAR MCAL , I have been configuring on tresos a group with 1 channel with the following properties: Single_access_Mode , One_Shot , SW_triggered , without Interrupts nor DMA.
the problem is when I try to implement the sequence diagram in the AUTOSAR ADC "Software triggered One-Shot conversion without notification"  , the api: Adc_GetGroupStatus  only returns the value of the conversion " TempReturn = Adc_axGroupStatus[Group].Conversion;" so the status is always ADC_BUSY.
My question is if the ADC driver is limited to work only using Interrupts or DMA ? I cannot use polling without a notification ( Interrupt).
1,153件の閲覧回数
VaneB
Hi @MohameddRIAD
ADC does not have a polling mode. As you said it works with DMA or interrupts.
I could suggest you the application note: S32K1xx ADC guidelines, spec and configuration.
B.R.
VaneB
1,154件の閲覧回数
VaneB
Hi @MohameddRIAD
B.R.
VaneB
