S32k JTAG pin reuse
S32k JTAG pin reuse
941件の閲覧回数
sarwath
Hello Community,
I am using SWD pins to dump the code and for debug purpose.
Now I want to use the JTAG pins to alternative mux functions. when I change the JTAG TDI (PTC 5) to FTM2_CH0 mux I am getting error in processor expert. I am not able to generate the code from processor expert. How to change the JTAG pins to alternative mux functions.
Could anyone please guide me on this.
BR,
Sarwath
タグ(2)
3 返答(返信)
904件の閲覧回数
VaneB
Hi @sarwath
I made the changes to the FTM2_CH0 pin, but I do not have any errors.
Could you share the steps you made?
B.R.
VaneB
894件の閲覧回数
sarwath
Hello @VaneB ,
1. I changed the pin mux from processor expert.
2. I changed  in FTM2 channel 0 to PTC5
At last I tried to generate the code from processor expert.
The above steps only I followed tp change the JTAG pin to FTM2 pin
BR,
Sarwath
877件の閲覧回数
VaneB
Hi @sarwath
Did you change any other pinouts in your project? If you change the configuration without using processor expert, do you still have the same error?
