S32K3xx: XRDC MRC instance for DFLASH
1,309 次查看
AndreasStolze
when looking at the MRC configuration table (chapter 19.1.2 table 68; ref manual rev 7), the program flash block PFLASH 0-3 are listed. However, I cannot find the DFLASH.
Is the DFLASH stated as "PFLASH_WR"?
If not, what is PFLASH_WR?
If yes: I could not find any reference between PFLASH_WR and DFLASH, as PFLASH_WR is used exactly 1 time in the whole ref manual.
Thank you
Andreas
1,284 次查看
danielmartynek
Hi Andreas,
All the ports have access to DFlash.
Use the RM MCAL RTD driver to configure the MRC0.
PFLASH_WR is for programming, discussed here already:
https://community.nxp.com/t5/S32K/XRDC-Memory-regions/td-p/1844979
1,285 次查看
danielmartynek
Hi Andreas,
1,270 次查看
AndreasStolze
Thanks, this was very helpful.
