Hi all,
请问S32K396和S32K376是pin to pin兼容吗?RM手册附件的IO 相关资料全都是S32K396的描述;
Are S32K396 and S32K376 Pin-to-PIN compatible? The IO related materials attached to the RM manual are all descriptions of S32K396;
解決済! 解決策の投稿を見る。
Hi Julián ,
I have understood, thank you for your support;
Hi all,
S32K396评估板文件包S32K396BMS-EVB-DESIGN-FILES.zip中,电路设计是基于S32K396,请问是否可以直接将MCU替换为S32K376?或需要进行怎样的改动?
In the s32K396 evaluation board file package S32K396BMS-EVB-DESIGN-FILES.zip, the circuit design is based on S32K396, can I directly replace the MCU with S32K376? Or what changes need to be made?
