S32K388EVB-Q289 board changes to use external debugger
已解决
跳至解决方案
1,136 次查看
DirkEtzler
The user manual for the S32K388EVB-Q289 mentions a modification of the board to use it with an external debugger.  Chapter 15.1 notes to disconnect J822 and J848 whereas chapter 15.2 of the same document requests to additionally remove the resistors R161, R181, R192 and R43.
When connecting a PEMicro  USB Universal FX or Segger J-Link Pro which of the chapters 15.1 or 15.2 does apply?  Do I need to remove the resistors or is it enough to open J822 and J848?
1 解答
491 次查看
DirkEtzler
Based on tests using the evaluation board, removing the jumpers J822 and J848 as well as the resistors R161, R181, R192, and R43 is necessary to have a stable operation with an external debugger, such as the PEMicro Multilink Universal or J-Link.  This should be clearly emphasized in the reference manual of the evaluation board.
在原帖中查看解决方案
6 回复数
492 次查看
DirkEtzler
778 次查看
DirkEtzler
I have checked the operation using an external PEMicro Universal FX debug probe and removing the jumpers J822 and J848 only.  Unfortunately, this setup leads to an unstable debug operation (e.g., starting the debug session for the first time seems to work, restarting the session leads to an error message while trying to connect).  I have not explored in detail why it behaves in that way.  I could repeat the setup and include the error messages if this proves to be helpful.  In a next step I will remove the resistors and rerun the tests.
1,076 次查看
Robin_Shen
Please wait for me to contact the Designer to confirm.
By the way, could you please take a photo and share your S32K388EVB-Q289 version information? for example:
Robin
1,060 次查看
DirkEtzler
I have attached the identification tags of my S32K388EVB-Q289 evaluation board.
937 次查看
Robin_Shen
I'm sorry for the delay.
This is the question I am not able to answer on our support level. I have escalated it to the Designer. I sent your photo to my colleague on September 30th, but have not received a reply yet. I left him another message today.  As soon as I have answer I'll send it to you.
813 次查看
Robin_Shen
I'm sorry to have kept you waiting.
I received a reply from my colleague yesterday: The Manufacturing team is in the process of confirming it.
I'll let you know as soon as I receive confirmation.
I don't have the RevB schematics, so I can't check the circuit. I haven't received the S32K388EVB-Q289 I ordered yet, so I can't test it. My colleague can perform SWD debugging through an external debugger after disconnecting J848 and J822.
%3CLINGO-SUB%20id%3D%22lingo-sub-2176968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K388EVB-Q289%20%E6%9D%BF%E6%94%B9%E4%B8%BA%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32K388EVB-Q289%20%E7%9A%84%E7%94%A8%E6%88%B7%E6%89%8B%E5%86%8C%E6%8F%90%E5%88%B0%E4%BA%86%E5%AF%B9%E6%9D%BF%E7%9A%84%E4%BF%AE%E6%94%B9%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%B0%86%E5%85%B6%E4%B8%8E%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%80%E8%B5%B7%E4%BD%BF%E7%94%A8%E3%80%82%E7%AC%AC%2015.1%20%E7%AB%A0%E6%8C%87%E5%87%BA%E8%A6%81%E6%96%AD%E5%BC%80%20J822%20%E5%92%8C%20J848%20%E7%9A%84%E8%BF%9E%E6%8E%A5%EF%BC%8C%E8%80%8C%E5%90%8C%E4%B8%80%E6%96%87%E4%BB%B6%E7%9A%84%E7%AC%AC%2015.2%20%E7%AB%A0%E8%A6%81%E6%B1%82%E5%8F%A6%E5%A4%96%E6%8B%86%E9%99%A4%E7%94%B5%E9%98%BB%E5%99%A8%20R161%E3%80%81R181%E3%80%81R192%20%E5%92%8C%20R43%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%9E%E6%8E%A5%20PEMicro%20USB%20%E9%80%9A%E7%94%A8%20FX%20%E6%88%96%20Segger%20J-Link%20Pro%20%E6%97%B6%EF%BC%8C%E7%AC%AC%2015.1%20%E7%AB%A0%E6%88%96%E7%AC%AC%2015.2%20%E7%AB%A0%E4%B8%AD%E7%9A%84%E5%93%AA%E4%B8%80%E7%AB%A0%E9%80%82%E7%94%A8%EF%BC%9F%20%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E6%8B%86%E4%B8%8B%E7%94%B5%E9%98%BB%E5%99%A8%EF%BC%8C%E8%BF%98%E6%98%AF%E6%89%93%E5%BC%80%20J822%20%E5%92%8C%20J848%20%E5%8D%B3%E5%8F%AF%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388EVB-Q289%20board%20changes%20to%20use%20external%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205520%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E4%BD%BF%E7%94%A8%E8%AF%84%E4%BC%B0%E6%9D%BF%E8%BF%9B%E8%A1%8C%E7%9A%84%E6%B5%8B%E8%AF%95%EF%BC%8C%E7%A7%BB%E9%99%A4%3CSPAN%3E%E8%B7%B3%E7%BA%BFJ822%E5%92%8CJ848%E4%BB%A5%E5%8F%8A%E7%94%B5%E9%98%BBR161%E3%80%81R181%E3%80%81R192%E5%92%8CR43%E6%98%AF%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%88%E4%BE%8B%E5%A6%82PEMicro%20M%3C%2FSPAN%3E%20%3CSPAN%3Eultilink%20Universal%E6%88%96J-Link%EF%BC%89%E5%AE%9E%E7%8E%B0%E7%A8%B3%E5%AE%9A%E8%BF%90%E8%A1%8C%E7%9A%84%E5%BF%85%E8%A6%81%E6%9D%A1%E4%BB%B6%E3%80%82%E8%AF%84%E4%BC%B0%E6%9D%BF%E7%9A%84%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E5%BA%94%E6%98%8E%E7%A1%AE%E5%BC%BA%E8%B0%83%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388EVB-Q289%20board%20changes%20to%20use%20external%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E5%A4%96%E9%83%A8%20PEMicro%20Universal%20FX%20%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E5%B9%B6%E5%8F%AA%E7%A7%BB%E9%99%A4%E8%B7%B3%E7%BA%BF%20J822%20%E5%92%8C%20J848%EF%BC%8C%E6%A3%80%E6%9F%A5%E4%BA%86%E8%BF%90%E8%A1%8C%E6%83%85%E5%86%B5%E3%80%82%20%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E8%BF%99%E7%A7%8D%E8%AE%BE%E7%BD%AE%E4%BC%9A%E5%AF%BC%E8%87%B4%E8%B0%83%E8%AF%95%E6%93%8D%E4%BD%9C%E4%B8%8D%E7%A8%B3%E5%AE%9A%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8C%E9%A6%96%E6%AC%A1%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E4%BC%BC%E4%B9%8E%E6%AD%A3%E5%B8%B8%EF%BC%8C%E4%BD%86%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E4%BC%9A%E8%AF%9D%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%8C%E5%90%8C%E6%97%B6%E5%B0%9D%E8%AF%95%E8%BF%9E%E6%8E%A5%EF%BC%89%E3%80%82%20%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E8%AF%A6%E7%BB%86%E6%8E%A2%E8%AE%A8%E5%AE%83%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BC%9A%E6%9C%89%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%E3%80%82%20%E5%A6%82%E6%9E%9C%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E9%87%8D%E5%A4%8D%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%B9%B6%E9%99%84%E4%B8%8A%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%E3%80%82%20%E4%B8%8B%E4%B8%80%E6%AD%A5%EF%BC%8C%E6%88%91%E5%B0%86%E6%8B%86%E9%99%A4%E7%94%B5%E9%98%BB%E5%99%A8%E5%B9%B6%E9%87%8D%E6%96%B0%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2189545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388EVB-Q289%20board%20changes%20to%20use%20external%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2189545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%AE%A9%E6%82%A8%E4%B9%85%E7%AD%89%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%98%A8%E5%A4%A9%E6%94%B6%E5%88%B0%E4%BA%86%E5%90%8C%E4%BA%8B%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%88%B6%E9%80%A0%E5%9B%A2%E9%98%9F%E6%AD%A3%E5%9C%A8%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B8%80%E7%BB%8F%E7%A1%AE%E8%AE%A4%EF%BC%8C%E6%88%91%E5%B0%86%E7%AB%8B%E5%8D%B3%E9%80%9A%E7%9F%A5%E6%82%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%B2%A1%E6%9C%89%20RevB%20%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%8C%E6%89%80%E4%BB%A5%E6%97%A0%E6%B3%95%E6%A3%80%E6%9F%A5%E7%94%B5%E8%B7%AF%E3%80%82%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E8%AE%A2%E8%B4%AD%E7%9A%84%20S32K388EVB-Q289%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%97%A0%E6%B3%95%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E3%80%82%20%E6%88%91%E7%9A%84%E5%90%8C%E4%BA%8B%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%96%AD%E5%BC%80%20J848%20%E5%92%8C%20J822%20%E8%BF%9E%E6%8E%A5%E5%90%8E%EF%BC%8C%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9B%E8%A1%8C%20SWD%20%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2182506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388EVB-Q289%20board%20changes%20to%20use%20external%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182506%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BE%88%E6%8A%B1%E6%AD%89%E8%80%BD%E8%AF%AF%E4%BA%86%E6%82%A8%E7%9A%84%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E5%9C%A8%E6%94%AF%E6%8C%81%E5%B1%82%E9%9D%A2%E6%97%A0%E6%B3%95%E5%9B%9E%E7%AD%94%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E4%B8%8A%E6%8A%A5%E7%BB%99%3CSPAN%3E%E8%AE%BE%E8%AE%A1%E5%B8%88%3C%2FSPAN%3E%E3%80%82%E6%88%91%E5%B7%B2%E4%BA%8E%209%20%E6%9C%88%2030%20%E6%97%A5%E5%B0%86%E6%82%A8%E7%9A%84%E7%85%A7%E7%89%87%E5%8F%91%E7%BB%99%E4%BA%86%E6%88%91%E7%9A%84%E5%90%8C%E4%BA%8B%EF%BC%8C%E4%BD%86%E5%B0%9A%E6%9C%AA%E6%94%B6%E5%88%B0%E5%9B%9E%E5%A4%8D%E3%80%82%E6%88%91%E4%BB%8A%E5%A4%A9%E5%8F%88%E7%BB%99%E4%BB%96%E7%95%99%E4%BA%86%E8%A8%80%E3%80%82%20%E4%B8%80%E6%97%A6%E6%9C%89%E4%BA%86%E7%AD%94%E6%A1%88%EF%BC%8C%E6%88%91%E5%B0%B1%E4%BC%9A%E5%8F%91%E7%BB%99%E4%BD%A0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2178150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388EVB-Q289%20board%20changes%20to%20use%20external%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2178150%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%B4%B4%E4%B8%8A%E4%BA%86%E6%88%91%E7%9A%84%20S32K388EVB-Q289%20%E8%AF%84%E4%BC%B0%E6%9D%BF%E7%9A%84%E8%AF%86%E5%88%AB%E6%A0%87%E7%AD%BE%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388EVB-Q289%20board%20changes%20to%20use%20external%20debugger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177758%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%AD%89%E6%88%91%E8%81%94%E7%B3%BB%E8%AE%BE%E8%AE%A1%E5%B8%88%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%82%A8%E8%83%BD%E6%8B%8D%E5%BC%A0%E7%85%A7%E7%89%87%E5%B9%B6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%20S32K388EVB-Q289%20%E7%89%88%E6%9C%AC%E4%BF%A1%E6%81%AF%E5%90%97%EF%BC%9F%20%E4%BE%8B%E5%A6%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32K388EVB-Q289%20Top%20View%20Verison.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32K388EVB-Q289%20Top%20View%20Verison.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F358956iF791A399D2E2D3D5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32K388EVB-Q289%20Top%20View%20Verison.png%22%20alt%3D%22S32K388EVB-Q289%20Top%20View%20Verison.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%E6%95%AC%E7%A4%BC%EF%BC%8C%3CBR%20%2F%3ERobin%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
