Need demo about FatFs - Generic FAT file system module with SDIO module by S32K358 RTD4.0.0, thanks.
I'm sorry that there is no example that fully meets your requirements.
Usually, these need to be completed by the user.
However, SD card is used in our T-BOX reference design, but it is simulated by FLEXIO, and the
RTD version is not the one you are using.
Hope this example can be helpful to you!
