- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi Team,
We are using S32K344 MCU. VOH, VOL Min & Max Value for IO Pin is not available in datasheet.
Please provide the same.
Only VIH & VIL min max details are there.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Noted!
Instead of considering Min/Max of the VOH/VOL , I can Consider this Typical VOH/VOL for my analysis,
VOH >= VDD_HV_A/B - 0.7V
VOL <= 0.7V
Is I am Correct ? Please confirm
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Apparently you can use it this way.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
VOH/VOL is indirectly stated within IOH and IOL specification as condition for this current measurement.
For instance for IOH_33 condition is VOH >= VDD_HV_A/B - 0.7V
V-I characteristic of the output pad can be estimated by linear approximation between points and <IOH_33; VDD_HV_A/B - 0.7V> and <0mA ; VDD_HV_A/B>.
The same way IOL_33 condition is VOL <= 0.7V.
It implies V-I characteristic as < IOL_33 ; 0.7V > and < 0mA ; 0V >
You may either estimate V-I characteristic as I described above or use IBIS simulation model.
