Hi NXP Expert,
Would you kindly provide a TEMPSENSE Demo code based on S32K344?
Many thanks
Sophie
Solved! Go to Solution.
Hi @danielmartynek ,How to set the adc tempsense voltage supply? How does the set value range 0-88 correspond to the voltage value? How to calculate the voltage value of the default value 53? Thanks very much.
Hello, Would you mind sending me, too?
