S32K344 In the case of high load rate on the CAN bus
CHYYDS
Hello everyone!!! I would like to ask you a question:
In the case of high load rate on the CAN bus (sending high priority messages through CANoe devices to achieve a bus load rate of 96%), the ECU sends a 10ms cycle message, with a maximum message cycle of more than 20ms. How can I solve this problem?
Thank you very much!!!
PetrS
if there is high bus load with high priority messages on the bus, then simply ECU could not be able to find free bus or/and to win bus arbitration and so sending of its message will be delayed until it is able to sent it. You cannot influence that, unless you will use even higher priority message.
BR, Petr
CHYYDS
@PetrSThank you for your reply
It's like this: send a high priority ID=0x01 on the bus to test the message cycle of the bus under high load. Is there any way to improve the delay of message cycles?
PetrS
std ID = 0x0 message has highest priority on the bus, so try this and be sure it is not transmitted by CANoe.
BR, Petr
