Hello
I read in the chip manual that if the DERR_SUP field in register PFCR4 is set to 1, single-bit and double-bit ECC events will not be reported. Will single-bit errors be repaired?
BestRegards,
Simon
Solved! Go to Solution.
Hello @danielmartynek
Thank you for your answer. I have a similar question: If the DMEEE bit in the same register PFCR4 is set, will a single-bit error be repaired?
BestRegards,
Simon
Yes, it has nothing to do with a single-bit ECC.
