Hi There,
We are configuring SPD-eMCEM in order to setup R1,R2,R3 fault reactions for S32K344.
Attached S32K3xx_fault_map,xlsx is also the attached fault configuration to the S32k3 reference manual.
I have a lot of problem to map it to R1, R2, R3 map (and in eMCEM NCF structure)
Can you give me an help ?
1) What does it mean (see S32K344 Tab) "Default Fault Enable" Set to No" (see column) How can I map it to eMCEM NCF configuration tab (S32DS Peripherial configuration view)?
2) What does it Mean "Default Fault Reaction" set to "Disabled" (see related column) and how can I map it to eMCEM NCF configuration tab?
3) I think that "Racomandation Recovery mechanism":
a)"Functional reset" stands for R3 fault reactions"
b)"Interrupt followed by SBC initiated POR recovery initiated in interrupt service routine" stands for R1 or R2 mechanism ?
c) "Interrupt" stands for R1 mechanism?
d)"Interrupt followed by a reset on the second fault" stands for R1+R3 ?
4) what does it mean "Error reaction path check" column? set to "yes"?
5) ehat does it mean "IP Supports Set/Clear by FCCU" set to "yes" for NCF0 , NCF1?
Fabio
已解决! 转到解答。
It means that faults default state (after reset) is set to NO = disabled.
Please refer to your driver documentation. But I can see the control if faults (NCFE_x registers) in the GUI directly (I am not familiar with it)
It means that out of reset (that is default state) the reaction is set to disabled. Again you can see it in GUI:
Interrupt from micro so it is R1 or R2 depends on fault config and then Reset by SBC that is R3 or Power on reset if you like.
From table below it is R1 or R2 and then R3.
Again, you can refer to documentation of SAF
It simply say that you can check the error reaction path by FCCU.
5) What does it mean "IP Supports Set/Clear by FCCU" set to "yes" for NCF0 , NCF1?
Set/ clear by FCCU means you can set and clear this fault by FCCU. (inject the fake fault or clear the lathed ones in FCCU_NCFSx registers)
best regards,
Peter
best regards,
Peter
