S32K344 EMIOS OUC problem
762 次查看
XPW
I have configured EMIOS0 with CH6 CH11 CH12 CH13 CH14 CH15, with a separate notification function for each channel. The problem now is that these notification functions no longer enter after a certain number of times.
4 回复数
711 次查看
_Leo_
Thank you for your interest in our products and for contributing to our community.
Please refer to the SAOC Example Project of the following community post:
S32M27x/S32K3 – eMIOS Usage -> https://community.nxp.com/t5/S32M-Knowledge-Base/S32M27x-S32K3-eMIOS-Usage/ta-p/2129760
We hope this resolves your issue.
677 次查看
XPW
Okay, I have identified the issue. When the newly written comparison value is 0, the situation I described earlier will occur
680 次查看
XPW
And at this point, return (0U!=(cpcxBase ->CH.UC [Channel]. C&eMIOS_C_SEN-MASK)? TRUE : FALSE; Always equal to TRUE
(0U != (cpcxBase->CH.UC[Channel].S & eMIOS_S_FLAG_MASK)) ? TRUE : FALSE; Always equal to False
688 次查看
XPW
I am glad to receive your reply. I have carefully reviewed the routine you provided, but the issue has not been resolved. I found that after no longer entering the OCU notification function, Interrupt handler for Emios channels 12-15 for Emios instance 0 is no longer triggered。(ISR(EMIOS0_2_IRQ))
