S32K344 - After interrupt is triggered, code is going to Default Handler.
ソリューションへジャンプ
126件の閲覧回数
siva_04
Hi Team,
I have configured the GPT interrupt and configured 3 tasks with different ticks like 1,2,3 seconds respectively. After the code will go to the default handler.
Could you please guide me?
103件の閲覧回数
danielmartynek
Hi @siva_04,
The error on EXC_RETURN can be caused by invalid context switch, corrupted stack on exception return.
For example, because of a stack overflow.
There is too little information in the description.
https://community.nxp.com/t5/S32K-Knowledge-Base/How-To-Debug-A-Fault-Exception-On-ARM-Cortex-M-V7M-...
BR, Daniel
104件の閲覧回数
danielmartynek
Hi @siva_04,
BR, Daniel
