Hello, under normal simulation conditions, the CM7_1 core can work normally, but when upgrading with bootloader, CM7_1 does not start working. What is the problem?
Hi @malei_22,
Do you enable CM7_1 in the boot header?
Is the CM7_1 clock running?
PRTN0_CORE1_STAT
