S32K324 ADC module initialization ADCPOT signal
1,946 次查看
Sanchita_Kochar
For S32k324, what is code for ADC module initialization and read result register w.r.t development board analog pin(ADCPOT signal)
4 回复数
1,927 次查看
Sanchita_Kochar
Can you please share link for
Adc_Sar_Bctu_Ip_example_S32K342
1,925 次查看
Senlent
Hi@Sanchita_Kochar
This demo can be found in S32 DS,I attached it for your reference!
1,923 次查看
Sanchita_Kochar
Thanks a lot
1,930 次查看
Senlent
Hi@Sanchita_Kochar
1.ADC Guidelines Spec and Configuration
https://www.nxp.com.cn/docs/en/application-note/AN13413.pdf
please take a look at the Chapter 5:SAR ADC Use cases.
2.RTD demos for your reference in S32 DS.
