S32K322 I want to know the difference between these two example
zyc0211
I2c_HLD_FLEXIO_Transfer_S32K344
I2c_IP_FLEXIO_Transfer_S32K344
That's the difference between this IP and HLD
zyc0211
PetrS
those are same examples using either high level driver (HLD) or low level driver (IP).
You can find overview of RTD driver within https://www.nxp.com/docs/en/application-note/AN13435.pdf
BR, Petr
zyc0211
that means HLD is autosar version?
