[S32K312] Get the Current Time via RTC
2,132 次查看
EdwinCYHuang
Hi Sir:
I have called the init function ( Rtc_Ip_Init -> Rtc_Ip_SetTimeDate -> Rtc_Ip_StartCounter ) , but when I try to get the hour , minutes and seconds via Rtc_Ip_GetTimeDate function . it doesn't change in every time.
thanks
Edwin Huang
2,112 次查看
danielmartynek
Hi @EdwinCYHuang,
Can you double-check the RTC clock?
What clock source did you seletect, and is the source clock enabled?
Thak you,
BR, Daniel
2,113 次查看
danielmartynek
Hi @EdwinCYHuang,
Thak you,
BR, Daniel
2,100 次查看
EdwinCYHuang
Hi  danielmartynek
I find the answer for it , we have no external clock (SXOSC_CLK) .
I set it to internal clock and log will show update time.
thanks for your response.
EdwinCYHuang
2,124 次查看
EdwinCYHuang
Here is my init function and result log.
