S32K312-Detailed description of PPB memory map
1,493 次查看
Simon-Liu
Contributor V
Hello
Can you provide a detailed description of the registers in the PPB memory map?
BestRegards,
Smion
1,456 次查看
VaneB
Hi @Simon-Liu
In section 3.9 (PPB memory map) of the S32K3xx Reference Manual, Rev. 7. Is mentioned that "PPB is a part of the defined Arm bus architecture".
If you require specific information, consult the documents provided by them.
B.R.
VaneB
1,457 次查看
VaneB
Hi @Simon-Liu
B.R.
VaneB
