S32K312 BusFault using AUTOSAR RTOS
798 次查看
eusebiudapatech
I am getting a BusFault at the following generated line:
The function is called in StartOs() function and it write the STM0 control register.
The code is generated from Tresos using the RTOS and RTD plugins.
I have checked the address and it's the correct STM0 control register address.
756 次查看
danielmartynek
Hi @eusebiudapatech,
Is the STM0 clock enabled?
MC_ME PRTN1_COFB0_STAT[29]
757 次查看
danielmartynek
749 次查看
eusebiudapatech
Thank you for the hint. I didn't call the Mcu_SetMode API to switch to RUN mode where STM0 is enabled. That solved the problem.
