S32K311 flash sector locked
LJS10045
I'm using S32K311, IDE version is S32DS 3.5 with RTD 4.0.
When I used Jlink v7.94 to program my .elf file, I encountered problem below :
ERROR: Failed to erase sectors 0 @ address 0x00400000 ((sector is locked))
Jlink can connect to MCU but I can't write, erase flash sector or chip.
I tried "unlock kinetis" and "erase all pin.jlk" in command line while under reset, but it also can't unlock either.
Is anyone encountered the same problem? Please let me know how to fix this.
Julián_AragónM
Hi @LJS10045,
Please help me checking this community post, as it seems these are similar issues: Cannot Use J-Flash to Erase or Write S32k311 chip - NXP Community
If the answer there does not fix your issue, I would recommend going to Segger: Ticket | SEGGER.
Julián
