S32K311 The FLASH failed to be erased AND a HardFault_Handler occurred
EvaKi
Hi NXP.
I use S32K311, RTD 3 to erase flash by using C40.
When I do some erase operation, the flash failed to be erased and triggered a hardfault
I added some debug messages in the C40_Ip_MainInterfaceSectorErase like the below:
We can see that when:
/* start internal erase/program sequence */
C40_Ip_pFlashBaseAddress->MCR |= FLASH_MCR_EHV_MASK; is executed,
Hardfault is triggered directly.
Sometimes, I step through debugging, step by step execution, but will erase successfully, will not trigger the hardfault error,
Is there a correct way to erase FLASH?
davidtosenovjan
It is apparetnly RWW issue. You must execute the code from different block or from internal SRAM as it is the same partition
久叶草
When debugging the S32K396 with S32DS 3.6.3 and RTD 6.0.0, I encountered a hardfault issue while testing the official Flash operation routine. Here is the situation:
If I set the program's pflash address to int_pflash : ORIGIN = 0x00400000, LENGTH = 0x00100000, then using C40_Ip_MainInterfaceSectorErase to erase the range 0x00500000 to 0x00502000 results in a hardfault. Erasing 0x005FE000 to 0x00600000 also causes a hardfault. However, erasing 0x00600000 to 0x00602000 works fine.
I tried placing the C40_Ip_MainInterfaceSectorErase function into the int_sram_fls_rsv : ORIGIN = 0x2045EF00, LENGTH = 0x00001000 section, but the hardfault still occurred. The issue was only resolved after I moved the main function into the int_sram_fls_rsv section as well.
Why is this happening? The erase sector size for S32K396 is 0x2000, but in practice, it seems erasing within a 0x00200000 length is not consistently allowed. I haven't found any documentation describing this behavior. Could there be a configuration issue on my end? I am using the C40_IP_Example_S32K396 example project.
Tags (3)
dujunqiu
hello,  must use 2 block?
EvaKi
davidtosenovjan
Do you have disabled cache?
EvaKi
Hi @davidtosenovjan
There are different caches that I had disabled.
This will still trigger Hardfault
1. #define C40_IP_SYNCRONIZE_CACHE (STD_OFF)
2. #define CACHE_IP_IS_AVAILABLE                        STD_OFF
EvaKi
I have done double verification, the area to be erased is indeed unlocked, so there should be no area to be erased is protected or the unlock fails, resulting in Hardfault error when erasing
EvaKi
If I set the PFLASH's .ld address to be in Block 0(512KB), such as use 200KB.
Then erase the remaining addresses, triggering an HardFault.
at the same time, If I erase the Block 1, everything is ok.
How to solve this condition?
The application scenario is that the Bootloader needs to erase the Flash address of the App
davidtosenovjan
Don't you execute this code from the same block you are trying to erase?
EvaKi
Hi @davidtosenovjan
The application scenario is that the boot program erases the app part, so the boot code and the app code will be in Block0, but in the same Block, erasing the App in the Boot will trigger hardfault
See this pic:
davidtosenovjan
dujunqiu
hello,which doc is this? i want to learn more
EvaKi
Hi @davidtosenovjan
Thanks for your support.
EvaKi
Erased area is PFLASH
%3CLINGO-SUB%20id%3D%22lingo-sub-1943892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1943892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP.%3C%2FP%3E%3CP%3EI%20use%20S32K311%2C%20RTD%203%20to%20erase%20flash%20by%20using%20C40.%3C%2FP%3E%3CP%3EWhen%20I%20do%20some%20erase%20operation%2C%20the%20flash%20failed%20to%20be%20erased%20and%20triggered%20a%20hardfault%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_0-1724979161082.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1724979161082.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1724979161082.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296158i26D465395B501FCE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_0-1724979161082.png%22%20alt%3D%22EvaKi_0-1724979161082.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20added%20some%20debug%20messages%20in%20the%26nbsp%3BC40_Ip_MainInterfaceSectorErase%20like%20the%20below%3A%3C%2FP%3E%3CP%3EWe%20can%20see%20that%20when%3A%26nbsp%3B%3C%2FP%3E%3CP%3E%2F*%20start%20internal%20erase%2Fprogram%20sequence%20*%2F%3CBR%20%2F%3E%3CFONT%20color%3D%22%23FF9900%22%3E%3CSTRONG%3EC40_Ip_pFlashBaseAddress-%26gt%3BMCR%20%7C%3D%20FLASH_MCR_EHV_MASK%3B%3C%2FSTRONG%3E%3C%2FFONT%3E%26nbsp%3B%3CSTRONG%3Eis%20executed%2C%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3EHardfault%20is%20triggered%20directly.%3C%2FP%3E%3CP%3ESometimes%2C%20I%20step%20through%20debugging%2C%20step%20by%20step%20execution%2C%20but%20will%20erase%20successfully%2C%20will%20not%20trigger%20the%20hardfault%20error%2C%3C%2FP%3E%3CP%3EIs%20there%20a%20correct%20way%20to%20erase%20FLASH%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_1-1724979192706.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_1-1724979192706.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_1-1724979192706.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296159i51F9A3A8B50411BD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_1-1724979192706.png%22%20alt%3D%22EvaKi_1-1724979192706.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_2-1724979244040.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_2-1724979244040.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_2-1724979244040.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296160iA57D14644F0520EB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_2-1724979244040.png%22%20alt%3D%22EvaKi_2-1724979244040.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_3-1724979313091.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_3-1724979313091.png%22%20style%3D%22width%3A%20203px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_3-1724979313091.png%22%20style%3D%22width%3A%20203px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296161i0C1DC88AC83206A4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_3-1724979313091.png%22%20alt%3D%22EvaKi_3-1724979313091.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2102381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2102381%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ehello%EF%BC%8Cwhich%20doc%20is%20this%3F%20i%20want%20to%20learn%20more%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2102376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2102376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%2C%26nbsp%3B%20must%20use%202%20block%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1951545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1951545%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FRWW-read-while-write%2Fm-p%2F1063397%22%20target%3D%22_blank%22%3ERWW%EF%BC%88read%20while%20write%EF%BC%89%20-%20NXP%20Community%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1951542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1951542%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52613%22%20target%3D%22_blank%22%3E%40davidtosenovjan%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThanks%20for%20your%20support.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1951050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1951050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20is%20apparetnly%20RWW%20issue.%20You%20must%20execute%20the%20code%20from%20different%20block%20or%20from%20internal%20SRAM%20as%20it%20is%20the%20same%20partition%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22davidtosenovjan_1-1725965798253.png%22%20style%3D%22width%3A%20639px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22davidtosenovjan_1-1725965798253.png%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22davidtosenovjan_1-1725965798253.png%22%20style%3D%22width%3A%20639px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F298265i64976C611E98750B%2Fimage-dimensions%2F639x61%3Fv%3Dv2%22%20width%3D%22639%22%20height%3D%2261%22%20role%3D%22button%22%20title%3D%22davidtosenovjan_1-1725965798253.png%22%20alt%3D%22davidtosenovjan_1-1725965798253.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1948859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1948859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52613%22%20target%3D%22_blank%22%3E%40davidtosenovjan%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThe%20application%20scenario%20is%20that%20the%20boot%20program%20erases%20the%20app%20part%2C%20so%20the%20boot%20code%20and%20the%20app%20code%20will%20be%20in%20Block0%2C%20but%20in%20the%20same%20Block%2C%20erasing%20the%20App%20in%20the%20Boot%20will%20trigger%20hardfault%3C%2FP%3E%3CP%3ESee%20this%20pic%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_0-1725608585305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1725608585305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1725608585305.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F297548iA64CC15E306F0602%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_0-1725608585305.png%22%20alt%3D%22EvaKi_0-1725608585305.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1948839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1948839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDon't%20you%20execute%20this%20code%20from%20the%20same%20block%20you%20are%20trying%20to%20erase%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1945923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1945923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20done%20double%20verification%2C%20the%20area%20to%20be%20erased%20is%20indeed%20unlocked%2C%20so%20there%20should%20be%20no%20area%20to%20be%20erased%20is%20protected%20or%20the%20unlock%20fails%2C%20resulting%20in%20Hardfault%20error%20when%20erasing%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1944889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1944889%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52613%22%20target%3D%22_blank%22%3E%40davidtosenovjan%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThere%20are%20different%20caches%20that%20I%20had%20disabled.%3C%2FP%3E%3CP%3EThis%20will%20still%20trigger%20Hardfault%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_3-1725239399560.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_3-1725239399560.png%22%20style%3D%22width%3A%20244px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_3-1725239399560.png%22%20style%3D%22width%3A%20244px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296410i0ACCDD98D2AB19D3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_3-1725239399560.png%22%20alt%3D%22EvaKi_3-1725239399560.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSTRONG%3E1.%26nbsp%3B%23define%20C40_IP_SYNCRONIZE_CACHE%20(STD_OFF)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_0-1725239151652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1725239151652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1725239151652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296407iBB386DFD3E7D12B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_0-1725239151652.png%22%20alt%3D%22EvaKi_0-1725239151652.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%26nbsp%3B%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3ECACHE_IP_IS_AVAILABLE%3C%2FSPAN%3E%3CSPAN%3E%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3BSTD_OFF%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_1-1725239235153.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_1-1725239235153.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_1-1725239235153.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296408iBADC4844F32CB7A2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_1-1725239235153.png%22%20alt%3D%22EvaKi_1-1725239235153.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_2-1725239343798.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_2-1725239343798.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_2-1725239343798.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296409i428EECBF9F22E793%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_2-1725239343798.png%22%20alt%3D%22EvaKi_2-1725239343798.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1944474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1944474%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDo%20you%20have%20disabled%20cache%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1944125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1944125%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIf%20I%20set%20the%20PFLASH's%20.ld%20address%20to%20be%20in%20Block%200(512KB)%2C%20such%20as%20use%20200KB.%3C%2FP%3E%3CP%3EThen%20erase%20the%20remaining%20addresses%2C%20triggering%20an%20HardFault.%3C%2FP%3E%3CP%3Eat%20the%20same%20time%2C%20If%20I%20erase%20the%20Block%201%2C%20everything%20is%20ok.%3C%2FP%3E%3CP%3EHow%20to%20solve%20this%20condition%3F%3C%2FP%3E%3CP%3EThe%20application%20scenario%20is%20that%20the%20Bootloader%20needs%20to%20erase%20the%20Flash%20address%20of%20the%20App%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_0-1724995839787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1724995839787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1724995839787.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F296216iC6258153E116585C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_0-1724995839787.png%22%20alt%3D%22EvaKi_0-1724995839787.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1943893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1943893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EErased%20area%20is%20PFLASH%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2291194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20The%20FLASH%20failed%20to%20be%20erased%20AND%20a%20HardFault_Handler%20occurred%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2291194%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EWhen%20debugging%20the%20S32K396%20with%20S32DS%203.6.3%20and%20RTD%206.0.0%2C%20I%20encountered%20a%26nbsp%3B%3C%2FSPAN%3Ehardfault%3CSPAN%3E%26nbsp%3Bissue%20while%20testing%20the%20official%20Flash%20operation%20routine.%20Here%20is%20the%20situation%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EIf%20I%20set%20the%20program's%20pflash%20address%20to%26nbsp%3B%3C%2FSPAN%3Eint_pflash%20%3A%20ORIGIN%20%3D%200x00400000%2C%20LENGTH%20%3D%200x00100000%3CSPAN%3E%2C%20then%20using%26nbsp%3B%3C%2FSPAN%3EC40_Ip_MainInterfaceSectorErase%3CSPAN%3E%26nbsp%3Bto%20erase%20the%20range%26nbsp%3B%3C%2FSPAN%3E0x00500000%3CSPAN%3E%26nbsp%3Bto%26nbsp%3B%3C%2FSPAN%3E0x00502000%3CSPAN%3E%26nbsp%3Bresults%20in%20a%20hardfault.%20Erasing%26nbsp%3B%3C%2FSPAN%3E0x005FE000%3CSPAN%3E%26nbsp%3Bto%26nbsp%3B%3C%2FSPAN%3E0x00600000%3CSPAN%3E%26nbsp%3Balso%20causes%20a%20hardfault.%20However%2C%20erasing%26nbsp%3B%3C%2FSPAN%3E0x00600000%3CSPAN%3E%26nbsp%3Bto%26nbsp%3B%3C%2FSPAN%3E0x00602000%3CSPAN%3E%26nbsp%3Bworks%20fine.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EI%20tried%20placing%20the%26nbsp%3B%3C%2FSPAN%3EC40_Ip_MainInterfaceSectorErase%3CSPAN%3E%26nbsp%3Bfunction%20into%20the%26nbsp%3B%3C%2FSPAN%3Eint_sram_fls_rsv%20%3A%20ORIGIN%20%3D%200x2045EF00%2C%20LENGTH%20%3D%200x00001000%3CSPAN%3E%26nbsp%3Bsection%2C%20but%20the%20hardfault%20still%20occurred.%20The%20issue%20was%20only%20resolved%20after%20I%20moved%20the%26nbsp%3B%3C%2FSPAN%3Emain%3CSPAN%3E%26nbsp%3Bfunction%20into%20the%26nbsp%3B%3C%2FSPAN%3Eint_sram_fls_rsv%3CSPAN%3E%26nbsp%3Bsection%20as%20well.%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3EWhy%20is%20this%20happening%3F%20The%20erase%20sector%20size%20for%20S32K396%20is%26nbsp%3B%3C%2FSPAN%3E0x2000%3CSPAN%3E%2C%20but%20in%20practice%2C%20it%20seems%20erasing%20within%20a%26nbsp%3B%3C%2FSPAN%3E0x00200000%3CSPAN%3E%26nbsp%3Blength%20is%20not%20consistently%20allowed.%20I%20haven't%20found%20any%20documentation%20describing%20this%20behavior.%20Could%20there%20be%20a%20configuration%20issue%20on%20my%20end%3F%20I%20am%20using%20the%26nbsp%3B%3C%2FSPAN%3EC40_IP_Example_S32K396%3CSPAN%3E%26nbsp%3Bexample%20project.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
