S32K311 Bootloader Jump to Application issue
2,103件の閲覧回数
EvaKi
I had a problem with the S32K311 bootloader jumping to the application. Cannot jump normally at present. I refer to posts in the forum, such as:
Example S32K312 Bootloader to Application Jump DS3.5 RTD300 - NXP Community
Unified bootloader Demo - NXP Community
Solved: S32K312 bootloader jump to application issue - NXP Community
These methods have been tried, but they can not jump normally, ld linker file is also configured with reference to the example,
The only successful jump is to download boot and app programs to MCU respectively and debug boot programs with S32DS. When I run them directly, I cannot jump to app. When I break the point at the jump function and stop running, I can jump to app program.
Try to use a delay period of time to jump again, can not, can only break the point to stop, and then run to the app program
Is the S32K311 program jump special compared to other S32K3x series?
Can the S32K311 bootloader successfully jump to the demo reference of the App?
S32K31XEVB-Q100
2 返答(返信)
1,037件の閲覧回数
kiran5
Hi Team,
Can you please share the solution for this issue. I am trying to jump from boootloader to application. But it is not working.
This is the Linker file of Bootloader .
MEMORY
ITCM (RWX) : ORIGIN = 0x00000000, LENGTH = 0x8000
PFLASH_BOOT (RX) : ORIGIN = 0x00400000, LENGTH = 0xA000
FW_VER_CONFIG (RX) : ORIGIN = 0x00419FE0, LENGTH = 0x20
/* Configuration Manager 1Kb */
CONFIG (RX) : ORIGIN = 0x0041A000, LENGTH = 0x400
PFLASH_BAF (RX) : ORIGIN = 0x004F4000, LENGTH = 0xC000
DFLASH (RX) : ORIGIN = 0x10000000, LENGTH = 0x10000
DTCM (RW) : ORIGIN = 0x20000000, LENGTH = 0x10000
SRAM0_STDBY (RW) : ORIGIN = 0x20400000, LENGTH = 0x2000
SRAM (RW) : ORIGIN = 0x20402000, LENGTH = 0x6000
This is the Linker file of application
MEMORY
PFLASH_APP (RX) : ORIGIN = 0x00480000, LENGTH = 0xFFE0
FW_VER_CONFIG (RX) : ORIGIN = 0x0048FFE0, LENGTH = 0x20
CONFIG (RX) : ORIGIN = 0x00490000, LENGTH = 0x400
I am using the following code to jump to application.
__disable_irq();
SCB->VTOR = 0x00480000;
func = *(uint32_t volatile *)(0x00480000 + 0xC);
func = *(uint32_t volatile *)(((uint32_t)func) + 0x4);
func = ((((uint32_t)func) & 0xFFFFFFFFU)); // Reset_Handler+1 --> required to avoid hard fault
(* (void (*) (void)) func)();
But jump to application is not happening.
Can you please support me on this.
Kiran
2,028件の閲覧回数
EvaKi
Solved
%3CLINGO-SUB%20id%3D%22lingo-sub-1915821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K311%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1915821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3C%2FP%3E%3CP%3ES32K311%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%8F%BE%E7%8A%B6%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K312-Bootloader-to-Application-Jump-DS3-5-RTD300%2Fta-p%2F1809810%22%20target%3D%22_blank%22%3ES32K312%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97DS3.5%20RTD300%E3%81%AE%E4%BE%8B%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FUnified-bootloader-Demo%2Fta-p%2F1423099%22%20target%3D%22_blank%22%3E%E7%B5%B1%E5%90%88%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%87%E3%83%A2%20-%20NXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K312-bootloader-jump-to-application-issue%2Ftd-p%2F1795729%22%20target%3D%22_blank%22%3E%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%3A%20S32K312%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E5%95%8F%E9%A1%8C%20-%20NXP%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%96%B9%E6%B3%95%E3%81%AF%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81ld%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E4%BE%8B%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%3C%2FP%3E%3CP%3E%E5%94%AF%E4%B8%80%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%AF%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AA%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%20MCU%20%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81S32DS%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%96%E3%83%BC%E3%83%88%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E7%9B%B4%E6%8E%A5%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97CAN%E3%80%82%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E6%A9%9F%E8%83%BD%E3%81%A7%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97CAN%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%85%E5%BB%B6%E6%9C%9F%E9%96%93%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%86%8D%E5%BA%A6%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81CAN%E3%81%AA%E3%81%84%E3%80%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%82%92%E7%A0%B4%E3%81%A3%E3%81%A6%E5%81%9C%E6%AD%A2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%97%E3%81%8B%E3%81%A7%E3%81%8D%E3%81%9A%E3%80%81%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_2-1721800907232.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_2-1721800907232.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290044iA83672AC4A224C50%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_2-1721800907232.png%22%20alt%3D%22EvaKi_2-1721800907232.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ES32K311%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%AF%E4%BB%96%E3%81%AE%20S32K3x%20%E3%82%B7%E3%83%AA%E3%83%BC%E3%82%BA%E3%81%A8%E6%AF%94%E3%81%B9%E3%81%A6%E7%89%B9%E5%88%A5%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3ES32K311%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%81%AE%E3%83%87%E3%83%A2%E5%8F%82%E7%85%A7%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97CAN%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32K31XEVB-Q100%2Fpd-p%2FS32K31XEVB-Q100%22%20class%3D%22lia-product-mention%22%20data-product%3D%223490-1%22%20target%3D%22_blank%22%3ES32K31XEVB-Q100%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_0-1721800178203.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_0-1721800178203.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290042iFFBACA9A5CFDE2A5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_0-1721800178203.png%22%20alt%3D%22EvaKi_0-1721800178203.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EvaKi_1-1721800372699.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EvaKi_1-1721800372699.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F290043iA367717C146E0FEA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22EvaKi_1-1721800372699.png%22%20alt%3D%22EvaKi_1-1721800372699.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2205178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20Bootloader%20Jump%20to%20Application%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2205178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%81%E3%83%BC%E3%83%A0%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8B%E3%82%89%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EITCM%20(RWX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x00000000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x8000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPFLASH_BOOT%20(RX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x00400000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200xA000%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EFW_VER_CONFIG%20(RX)%20%3A%20ORIGIN%20%3D%200x00419FE0%E3%80%81LENGTH%20%3D%200x20%3C%2FP%3E%3CP%3E%2F*%20%E6%A7%8B%E6%88%90%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%83%BC%201KB%20*%2F%3C%2FP%3E%3CP%3E%E6%A7%8B%E6%88%90%EF%BC%88RX%EF%BC%89%EF%BC%9AORIGIN%20%3D%200x0041A000%E3%80%81LENGTH%20%3D%200x400%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPFLASH_BAF%20(RX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x004F4000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200xC000%3C%2FP%3E%3CP%3EDFLASH%20(RX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x10000000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x10000%3C%2FP%3E%3CP%3EDTCM%20(RW)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x20000000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x10000%3C%2FP%3E%3CP%3ESRAM0_STDBY%20(RW)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x20400000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x2000%3C%2FP%3E%3CP%3ESRAM%20(RW)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x20402000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x6000%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%A2%E3%83%AA%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EITCM%20(RWX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x00000000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x8000%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3EPFLASH_APP%20(RX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x00480000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200xFFE0%3C%2FP%3E%3CP%3EFW_VER_CONFIG%20(RX)%20%3A%20ORIGIN%20%3D%200x0048FFE0%E3%80%81LENGTH%20%3D%200x20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%A7%8B%E6%88%90%EF%BC%88RX%EF%BC%89%EF%BC%9AORIGIN%20%3D%200x00490000%E3%80%81LENGTH%20%3D%200x400%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EPFLASH_BAF%20(RX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x004F4000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200xC000%3C%2FP%3E%3CP%3EDFLASH%20(RX)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x10000000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x10000%3C%2FP%3E%3CP%3EDTCM%20(RW)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x20000000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x10000%3C%2FP%3E%3CP%3ESRAM0_STDBY%20(RW)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x20400000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x2000%3C%2FP%3E%3CP%3ESRAM%20(RW)%20%3A%20%E5%8E%9F%E7%82%B9%20%3D%200x20402000%E3%80%81%E9%95%B7%E3%81%95%20%3D%200x6000%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E__disable_irq()%3B%3C%2FP%3E%3CP%3ESCB-%26gt%3BVTOR%20%3D%200x00480000%3B%3C%2FP%3E%3CP%3E%E9%96%A2%E6%95%B0%20%3D%20*(uint32_t%20volatile%20*)(0x00480000%20%2B%200xC)%3B%3C%2FP%3E%3CP%3Efunc%20%3D%20*(uint32_t%20volatile%20*)(((uint32_t)func)%20%2B%200x4)%3B%3C%2FP%3E%3CP%3Efunc%20%3D%20((((uint32_t)func)%20%26amp%3B%200xFFFFFFFFU))%3B%20%2F%2F%20Reset_Handler%2B1%20--%26gt%3B%20%E3%83%8F%E3%83%BC%E3%83%89%E3%83%95%E3%82%A9%E3%83%BC%E3%83%AB%E3%83%88%E3%82%92%E5%9B%9E%E9%81%BF%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%3C%2FP%3E%3CP%3E(*%20(void%20(*)%20(void))%20%E9%96%A2%E6%95%B0)()%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%B8%E3%81%AE%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%AD%E3%83%A9%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1917828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32K311%20Bootloader%20Jump%20to%20Application%20issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1917828%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E6%B1%BA%E6%B8%88%E3%81%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E
