S32K310 Pinout mapping not found in the IOMUX.xlsx
1,790,743 次查看
SSK_2023
I am doing pin to pin compatibility check for S32K310 vs S32K311 (48 LQFP)
while referring the IOMUX.xlsx, S32K310 pinout is not listed in the excel.
Can anyone help on this topic?
6 回复数
1,790,728 次查看
VaneB
Hi @SSK_2023
It is not explicitly mentioned, but the S32K310 and the S32K311 are pin-to-pin compatible.
Sorry for the inconvenience.
B.R.
VaneB
1,790,724 次查看
SSK_2023
Hello VaneB,
Thank you for the feedback,
Can you please share the updated xlsx sheet for usage.
1,790,715 次查看
VaneB
Hi @SSK_2023
The latest S32K311_S32K310_IOMUX version is included in the S32K3xx Reference Manual, Rev. 5.
I am attaching it here for easy reference.
1,790,694 次查看
SSK_2023
Hello VaneB, Good Day!
I checked in S32K3xx Reference Manual, Rev. 5 linked excel sheet and also the excel sheet shared by you, both does not have the S32K310 pin out listed.
I understand that S32K310 and S32K311 are pin to pin compatible, but i cannot able to convince the counter part with the details available.
Can you please share the excel with both S32k310 and S32k311 pin outs listed.
only S32K311 is listed, refer the below image
1,790,685 次查看
VaneB
Hi @SSK_2023
Sorry about the inconvenience this may cause. The document included in the S32K3xx Reference Manual, Rev. 5, is the only one provided to the public. If you need an excel file that explicitly lists the pin out of the S32K310 and S32K311, please contact your local NXP representative o FAE.
1,790,732 次查看
SSK_2023
