S32K3 packages BXL files?
hns80
Contributor V
Are BXL (Ultralibrarian) files available for the S32K3 families?
Even better would be getting them in native Altium format. I tried importing the Cadence files into Altium without success.
Tags (2)
hns80
Contributor V
I paid someone to convert it from Allegro to Altium. The converted library is attached in case anyone else needs it.
Jeremy_He
You can also search the S32K3 symbols and footprint on https://www.snapeda.com/search/?q=S32K3&search-type=parts
Most of them are already there.
Jeremy
hns80
Contributor V
hns80
Contributor V
MaxQFP-100 and MaxQFP-172 packages for the S32K312.
Thank you,
Jeff
danielmartynek
Hello Jeff,
The BXL files are not yet available.
Regarding the Altium format, let me ask around.
Do you have a specific part in mind?
hns80
Contributor V
Saving the library files in ASCII format would allow customers to import them into Altium. I believe this is done with dbdoctor (Cadence tool).
hns80
Contributor V
I found the 172 pin package footprint in Altium footprint (attached for those needing it).
I just need the 100 pin footprint now.
danielmartynek
Hello Jeff,
I'm sorry for the delay, I contacted the responsible team for the models, but I haven't received a clear answer yet. I'm afraid it might take some additional time.
