S32K3 Module_CLK
S32K3 Module_CLK
Embedded_novice
我在手册中看到CAN这个模块的时钟来源是只有AIPS_PLAT_CLK,但是在S32DS配置工具中却可以选择AIPS_PLAT_CLK以及SOSC和FIRC,,我想知道是我在使用参考手册时看的章节错了吗?同样的问题还有例如LSPI在手册中时钟来源是有AIPS_PLAT_CLK和AIPS_SLOW_CLK,但是在配置工具中只能选择AIPS_SLOW_CLK。
Senlent
Hi@Embedded_novice
S32K3xx Reference Manual, Rev. 9, 07/2024,Chapter:"24.3.4 Other clocks"
Senlent
Hi@Embedded_novice
1.你可以看到FlexCAN模块的时钟有两个,在你提供的截图中已经可以看到了,分别是"CAN_CHI_CLK"和"CAN_PE_CLOCK",
其中“CAN_CHI_CLK”的时钟默认是“AIPS_PLAT_CLK”,不需要配置,你需要配置的是“CAN_PE_CLOCK”,其可以有“AIPS_PLAT_CLK”,“FXOSC_CLK”和“FIRC”三个选择。
2.LPSPI在S32K3中,不同的LPSPI的实例是不一样的,LPSPI0是属于高性能的,其外设时钟是“AIPS_PLAT_CLK”,对于其它的LPSPIx,如SPI1或者SPI2是普通的,其时钟源是“AIPS_SLOW_CLK”。
Embedded_novice
我想知道CAN_PE_CLOCK的时钟源是从哪里看到有“AIPS_PLAT_CLK”,“FXOSC_CLK”和“FIRC”三个选择的,因为我没有在参考手册中看到相关的描述(有漏看的可能)。如果你知道出处的话能告诉我吗?感谢!
Senlent
Hi@Embedded_novice
%3CLINGO-SUB%20id%3D%22lingo-sub-2048672%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ES32K3%20Module_CLK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048672%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20saw%20in%20the%20manual%20that%20the%20clock%20source%20for%20the%20CAN%20module%20is%20only%20AIPS_PLAT_CLK%2C%20but%20in%20the%20S32DS%20configuration%20tool%2C%20I%20can%20choose%20AIPS_PLAT_CLK%20as%20well%20as%20SOSC%20and%20FIRC.%20I%20want%20to%20know%20if%20I%20read%20the%20wrong%20chapter%20when%20using%20the%20reference%20manual%3F%20The%20same%20problem%20also%20exists%20for%20example%2C%20in%20the%20manual%2C%20the%20clock%20sources%20for%20LSPI%20are%20AIPS_PLAT_CLK%20and%20AIPS_SLOW_CLK%2C%20but%20in%20the%20configuration%20tool%2C%20only%20AIPS_SLOW_CLK%20can%20be%20selected.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RM.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RM.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325069i75E9D3B0E30896F4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22RM.png%22%20alt%3D%22RM.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22S32DS.png%22%20style%3D%22width%3A%20653px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22S32DS.png%22%20style%3D%22width%3A%20653px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325068iF268F64917067148%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22S32DS.png%22%20alt%3D%22S32DS.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2049519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20Module_CLK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2049519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ES32K3xx%20Reference%20Manual%2C%20Rev.%209%2C%2007%2F2024%2CChapter%3A%22%3CSTRONG%3E24.3.4%20Other%20clocks%3C%2FSTRONG%3E%22%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Capture.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Capture.JPG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F325256i2F2AA5440D8C6B31%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Capture.JPG%22%20alt%3D%22Capture.JPG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048846%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20Module_CLK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048846%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3EI%20want%20to%20know%20where%20I%20can%20see%20the%20three%20options%20of%20CAN_PE_CLOCK%20clock%20source%3A%20%22AIPS_PLAT_CLK%22%2C%20%22FXOSC_CLK%22%20and%20%22FIRC%22%2C%20because%20I%20don't%20see%20the%20relevant%20description%20in%20the%20reference%20manual%20(I%20may%20have%20missed%20it).%20If%20you%20know%20the%20source%2C%20can%20you%20tell%20me%3F%20Thanks!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2048799%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20Module_CLK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2048799%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E1.%20You%20can%20see%20that%20the%20FlexCAN%20module%20has%20two%20clocks%2C%20which%20can%20be%20seen%20in%20the%20screenshot%20you%20provided%2C%20namely%20%22%20%3CSTRONG%3ECAN_CHI_CLK%3C%2FSTRONG%3E%20%22%20and%20%22%20%3CSTRONG%3ECAN_PE_CLOCK%3C%2FSTRONG%3E%20%22.%3C%2FP%3E%0A%3CP%3EThe%20default%20clock%20of%20%22CAN_CHI_CLK%22%20is%20%22%20%3CSPAN%3EAIPS_PLAT_CLK%3C%2FSPAN%3E%20%22%2C%20which%20does%20not%20need%20to%20be%20configured.%20What%20you%20need%20to%20configure%20is%20%22CAN_PE_CLOCK%22%2C%20which%20has%20three%20options%3A%20%22%20%3CSPAN%3EAIPS_PLAT_CLK%3C%2FSPAN%3E%20%22%2C%20%22FXOSC_CLK%22%20and%20%22FIRC%22.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.%20LPSPI%20In%20S32K3%2C%20different%20LPSPI%20instances%20are%20different.%20LPSPI0%20is%20high-performance%20and%20its%20peripheral%20clock%20is%20%22%20%3CSPAN%3EAIPS_PLAT_CLK%3C%2FSPAN%3E%20%22.%20For%20other%20LPSPIx%2C%20such%20as%20SPI1%20or%20SPI2%2C%20they%20are%20ordinary%20and%20their%20clock%20source%20is%20%22%20%3CSPAN%3EAIPS_SLOW_CLK%3C%2FSPAN%3E%20%22.%3C%2FP%3E%3C%2FLINGO-BODY%3E
