S32K3 HSE demo_app
S32K3 HSE demo_app
IAussman
I'm currently trying to flash the demo_app HSE binary into the S32K344 via Trace32 Lauterbach.
I've followed all the different steps described in document:
HSE_DEMOAPP_S32K3XX_0_2_1_0_ReadMe.pdf
When I launch in User menu the option: Load Demo App binary, I always got this error message.
For information I'm using Trace32 version R.2022.02.000147047
Any suggestions would be welcome.
alwin
Have you solved your problem?
I got the same error message as you, and I modified some .cmm files
under path '\HSE_DEMOAPP_S32K3XX_0_2_1_0\demo_security_installer\scripts' to fixed the problem
IAussman
Yes thanks, the problem has been solved.
I've flashed the demo application by using s32k3.cmm script.
BR,
steffen_krausse
In case the HSE is involved, I recommend to contact the Lauterbach support directly.
Steffen.
