S32K3 FLASH write
S32K3 FLASH write
DouDou1
Hi, everyone
I am using the first core of the S32K358 chip to program, I want to put the BOOTLOADER program in the memory of PFLASH0, and then put the APP program in the memory of PFLASH1, can the APP run properly?
lukaszadrapa
It doesn't matter which master accesses a flash block.
There's simple rule - if a block is being erased or programmed, it's now allowed to access this block. Only other blocks can be accessed at that time.
Lukas
lukaszadrapa
Hi @DouDou1
Yes, there's no problem with this setup. There are four code flash blocks and read-while-write is supported between these blocks.
Lukas
DouDou1
Hi,@lukaszadrapa,
Thank you for your reply, I want to know if the first core of the S32K358 chip can read-while-write all four code?
lukaszadrapa
Lukas
DouDou1
Thank you for your reply.
%3CLINGO-SUB%20id%3D%22lingo-sub-2013485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%20FLASH%20write%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2013485%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20everyone%3C%2FP%3E%3CP%3EI%20am%20using%20the%20first%20core%20of%20the%20S32K358%20chip%20to%20program%2C%20I%20want%20to%20put%20the%20BOOTLOADER%20program%20in%20the%20memory%20of%20PFLASH0%2C%20and%20then%20put%20the%20APP%20program%20in%20the%20memory%20of%20PFLASH1%2C%20can%20the%20APP%20run%20properly%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2016742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20FLASH%20write%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2016742%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20reply.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2015893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20FLASH%20write%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2015893%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EIt%20doesn't%20matter%20which%20master%20accesses%20a%20flash%20block.%3C%2FP%3E%0A%3CP%3EThere's%20simple%20rule%20-%20if%20a%20block%20is%20being%20erased%20or%20programmed%2C%20it's%20now%20allowed%20to%20access%20this%20block.%20Only%20other%20blocks%20can%20be%20accessed%20at%20that%20time.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2015759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20FLASH%20write%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2015759%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%40lukaszadrapa%2C%3CBR%20%2F%3EThank%20you%20for%20your%20reply%2C%20I%20want%20to%20know%20if%20the%20first%20core%20of%20the%20S32K358%20chip%20can%20read-while-write%20all%20four%20code%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2015064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K3%20FLASH%20write%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2015064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230579%22%20target%3D%22_blank%22%3E%40DouDou1%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%2C%20there's%20no%20problem%20with%20this%20setup.%20There%20are%20four%20code%20flash%20blocks%20and%20read-while-write%20is%20supported%20between%20these%20blocks.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
