I'm looking for some clarification regarding the AB Swap functionality. Here the questions:
1. Is it possible to do an AB Swap without the HSE (only sBAF)? Or is HSE required? Is there some demo app for this?
2. Is it possible to change the size of the AB Swap blocks? For example on a S32K312 use only 128 KB (x2 256 KB) and than use the remaining space for other purposes?
Solved! Go to Solution.
Hi Vincenzo,
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-STDSW-D
https://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=SW32K3-REFSW-D
Lukas
Hi Vincenzo,
Lukas
hi lucas,
Can you tell me that where can i download the SW32K3_OTADEMO_0.8.0_D2203?
thanks a lot.
Hi, probably this is another reply...
