S32K1xx unified bootloader
liyangcheng
Hi Expert:
Could you please provide the Flash driver‘s source code to me?
Because I only find bootloader's project from the website.Thanks!
liyangcheng
S32K1xx_unified_bootloader_demo_V1.0\S32K1xx
Porting\S32K142_CAN
UDS_stack\unified_bootloader_stack\Source
Two folders copy to
Project\S32DS\S32K142_CAN\S32K142_CAN_bootloader\Sources
ing
May I ask what the problem is, I use S32DS V2.2 for ARM
liyangcheng
Porting\S32K142_CAN
Two folders copy to
Senlent
Hi@liyangcheng
I don't know what you want to express, can you make it clear?
Senlent
Hi@liyangcheng
You can find S32K142 flash driver source code in this path.
....\S32K1xx_unified_bootloader_demo_V1.0\S32K1xx\Project\S32DS\S32K142_CAN
I did not find S32K144 Flash driver source code, but it should be same,you can try to modifiy S32K142 flash driver to meet your needs.
BR!
     Jim,
