S32K148EVB-Q176 SPI lines issues
Saitej
Hello NXP
Am using S32K148 EVB for my developments and here am trying to communicate with different sensors over SPI, when ever am talking to sensor over SPI MISO lines is not behaving as expected and the results are inconsistent. Where am successfully able to talk with those sensors using third party EVB's.
Do we need any additional circuit for the SPI lines ?,
Tags (5)
PetrS
no additional circuit is needed. You should have proper connection and use right protocol as slave's need. What SPI module do you use, what is your connection between sensor and EVB? Do you have scope screen of bus signals?
BR, Petr
