S32K148EVB-Q176 Development Kit is not recognized by PC
1,994 次查看
CanCan
I have S32K148EVB-Q176 Development Kit and I am trying to connect it to my PC via its micro-USB port. But my PC does not even recognize that something is plugged to its USB port. I checked if I had any restrictions on my ports. I do not. I adjusted the pin configurations so that it takes the power from usb but still nothing. What should I do ?
1,939 次查看
Miguel04
Hi @CanCan
Thank you for the information.
Do you have an external debugger? This way you can try to connect to the evaluation kit and verify if the problem is from the S32K148 or the integrated debugger.
Miguel.
4 回复数
1,952 次查看
CanCan
Hi @Miguel04,
I checked the configurations and my jumper configurations are as shown in the guide. I also tried to connect to my PC using the provided cable and with another one. Is there a possibilty that my micro-usb port is damaged and not working? I do not recognize that I've been harsh to the board. It feels that that is a low possibilty.
1,940 次查看
Miguel04
Hi @CanCan
Miguel.
1,731 次查看
CanCan
Problem has solved. Thanks for the help
1,975 次查看
Miguel04
Hi @CanCan
I would like to confirm that the jumper configuration of your S32K148EVB-Q176 correct.
Please look into this Getting started guide and compare the configuration of Step 3.1 Set Up Jumpers with your own.
Best Regards, Miguel.
