S32K148 software can be loaded to S32K144 board?
VinhNguyen13
Hello all,
I am using the sample software provided by NXP for S32K148 dev boar. But now, I only have the S32K144 board available. Can I use this SW for that kit? Is there any update required? Please share the information, thank you.
dianabatrlova
I'm not sure if that means you've solved your question.
However, if you have additional questions related to this case, let me know.
Diana
dianabatrlova
Which sample SW do you use? There is a possibility that the SW is already ported to S32K144.
The MCUs have differences in memory sizes, peripherals, also, some pins are connected differently on each board. So, it is possible to port the SW to S32K144 but depends on your application how many changes will be needed.
Diana
VinhNguyen13
Hi Diana,
I am using S32K144 Evaluation board. I had the corresponding sw to use. Thank for your support.
dianabatrlova
Diana
