S32K148 lwip+freertos+phy
15736231627
Hello, I found that the phy used in the Lwip_S32K148 routine of SDK is TJA1011, but I want to use another PHY such as KSZ8041,. Which parts of the program should I modify to communicate, such as ping??
jiabingqiang
王工,我最近也在调试这个单片机,遇到了一些问题,尤其是LIN通讯,用 SDK 经常提示busy,我是做汽车的,要用到RTOS,Boot,CAN,LIN,ADC,PWM,休眠唤醒等模块,目前正在调试中,是否可以加个微信?资源共享下,我微信号    genhao35
how to place variable in allocate ram section?
JackChen2022
请问一下这个s32k148搭配其他phy芯片,debug返回busy状态有解决办法吗
