S32K148 can not download program to flash
LSLLL
Maybe the mcu locked,but use JLink can not unlock,the Reset Pin is grounded.The program runs normally.
Robin_Shen
Hi wl z,
Please read the MDM_AP status and control registers by refer the steps descripted in Unbricking S32K146.
Robin
LSLLL
Thanks,but now i think the debug interface can not be used,because i can not find mcu through the J-Link Commander.
Robin_Shen
Before input "unlock kinetis", you should follow the tips of JLink Commander( Type "connect" to establish a target connection)
LSLLL
Sure,I tried again and again.
Robin_Shen
If it's your custom board, then please check the SWD connection by refer:AN5426: Hardware Design Guidelines for S32K1xx – Application Note
If you are using S32K148EVB, have you tried to debug it with onboard OpenSDA?
LSLLL
Thanks for your reply,it's my custom board,I use multimeter check the SWD connection and it's no problem.
